sind wir glücklich :thumbup: forgemotorsport.at - FMDVA1TSI - Blow Off Valve Audi A1 1.4 Turbo FMDVA1TSI
This valve has been specifically designed for the Audi A1 1.4 Turbo (122hp) engine. This is a full replacement atmospheric blow-off valve that integrates seamlessly with the OEM electronics and results in absolutely no fault codes, no check engine lights, and no detriment to the performance of the vehicle in any way. Like our many TSI replacement valve options, the valve is fully engineered to remedy the failure issues associated with the OEM solenoid valves. Our valve uses full billet alloy construction with a piston based internal design that provides for significantly improved reliability over the OEM valves along with lightning fast response. The valve is supplied with all the necessary parts required to make installation an easy as possible. 185 PS.... weis ich nicht
Das gibt's auch für den 185er... War auch mal kurz davor mir die offene Variante zu bestellen, lasse es jetzt aber sein, da er eh nächstes Jahr zurück geht. Beim Neuen kommt das, in Kombination mit Chip und größerem LLK, aber auf jeden Fall rein. :thumbup:
