Hello You know how to change this to Vagcom? -Disable the mirror interior day / night -Disable the start and stop -Keep the same intensity LEDs with flashing Thank you
1. dunno 2. http://www.a1talk.de/audi-a1-anleit...34-vcds-deaktivierung-start-stopp-system.html 3. stemei.de .website von Stefan Meier .VCDS coding .webdesign .IT solutions - LED TFL Blinker dimmen
I have interior mirror Automatic (day / night). It is possible to disable via a button located above, but I want to completely disable whith the Vagcom.
Well, I don't have an answer for you, because I don't know it. But I've to ask, W waht do you mean with "interior mirror automatic"? The "rear-view mirror atumatic"? If so, it should have this button (as you said) to deactivate the funcationality and in my opinion it is the easiest way. Best regards. Scie P.S. I've to admit, even if my answer was completly dumb, I would respond again, because I don't like it, if someone asks a question in a foreign language and won't get a response.
Actually on the inside mirror will have one button to turn off automatic but I want to turn it off completely using the Vagcom for failing to press the button on every boot. I asked in German with a translator but I have not had a reply ... May be you who understand my question can you translate it into German for that other person answer me? Thank you
Ok, I'll try. Below you'll find your question and explanation in German, if I'm not mistaken: Calzon möchte wissen, ob es möglich ist den automatisch abblendenden Innenspiegel über das VCDS/Vagcom komplett zu deaktivieren? Aktuell scheint es so zu sein, dass die Funktion, wenn man diese über den Knopf am Spiegel deaktiviert, beim nächsten Neustart des Wagens wieder aktiviert ist und man erneut den Knopf betätigen muss. MfG Scie
